Some assets needed to load the file were missing.
/data/DAZ 3D/Genesis/Base/Genesis.dsf
Not been able to find an answer so please help.
This problem started because I was trying to fix Daz as my Victoria 6 model also had a similar issue with not finding the files.
Edited to add subject to body of post
What that error usually means, is that your content directories are not set up properly.
Did you install Genesis Starter Essentials AND Genesis 2 Starter Essentials?
Did you use DIM (DAZ Install Manager) to install them?
If so, make sure that the correct paths are listed in Edit > Preferences > Content Library > Content Directory Manager under Poser and DAZ Studio Formats.
Thank you so much it works!!
the same thing comes for me "some assets needed...." for the DA OLD OAK TREE. could u help with this please?
How did you install it, using DAZ Install Manager? If so, DAZ Install Manager installs to C:\Users\Public\Documents\My DAZ 3D Library by default, and you need to make sure that path is listed in Edit > Preferences > Content Library > Content Directory manager under both Poser and DAZ Studio formats.
