Thumbnails and Icons
ZamuelNowZamuelNow Posts: 753
-How do you prevent DS from making icons every time you render?
-To my understanding, the system can read thumbnail images larger than 100x100 pixels. How do you go about this, just manually render an image larger than that and then rename it?
  • LindseyLindsey Posts: 2,017
    IIRC, DS generates icons for renders saved to a folder defined in the Render Library tab
  • Richard HaseltineRichard Haseltine Posts: 112,049
    I use the Render Library Manager, in the Render Library option menu, to set a folder without images as the only location listed. I then close the render Library and the next time I render I use the menu to the left of the file location to tell it to save to a folder rather than a library, and point it to the folder I really want my images in.
