Dark areas on my mesh?
Eternal ForceEternal Force Posts: 307
edited December 2021 in Daz Studio Discussion
Hello guys,
I have a very basic question. I've noticed these strange black areas on my custom low res mesh. Is DAZ Studio trying to warn me that there is a problem with my geometry? Or is it something that can be safely ignored?
1389 x 1000 - 257K
Post edited by Eternal Force on
  • margravemargrave Posts: 1,822
    That can have any number of issues like the normals being reversed, overlapping geometry, a mix of flat and smooth shading, etc.
    What did you model it in?
  • That could be: Bad normals; "Good" normals on "bad" (non-planar ) quads; Non-manifold geometry. If you're going to use a normal map, I'm not even sure I'd bother to fix it unless the problem also exists in the UV.
  • Looks like it needs a tessellation line near to the edge - that's done back in the modeler.
    Thank you!!! I am indeed going to use a normal map. Just trying to stay on the safe side here.
  • Eternal ForceEternal Force Posts: 307
    Thank you!!! You gave me an idea!!!  cheeky  When you mentioned "a mix of flat and smooth shading", I started to look in the Internet for smooth shading in DAZ studio. And I've found my answer!
    Smooth Shading is enabled by default for the Iray Uber Shader. It can be found on the Surfaces Tab.  When I turn Smooth Shading off, the dark areas dissaper completely! Probably it is because my mesh is too low poly for Smooth Shading to work with.
    527 x 441 - 69K
    Thank you, Catherine!  What is a tesselation line? Do you mean that I need to add an additional edge loop?
