Problem with Marvelous Bodysuit for G8M and G8F
Hello,
I have purchased the Marvelous Bodysuit for both G8M and G8F as well as their associated texture expansion packages and I am having trouble applying the textures to these suits. In the case of the female suit I can aplly the textures sucessfully to the belt, boots, mask and gloves but they won't apply to the suit itself. In the case of the male suit, the mask, gloves and boot textures will apply but not the belt or suit textures. I have tried this with the suit applied to a character and with just the suit in the scen with the same result. I have tried re-installing the suits and again have had no success.  Any help with this would be greatly appreciated.
I am using Studio 4.15.0.30 and I have attached a screenshot of the error message and the log file.
1127 x 1121 - 107K
txt
txt
log.txt
1K
  • felisfelis Posts: 6,561
    It gives error for a hieracical preset, meaning that you need to have the G8 character wearing the suit, and then select that when applying the material.
  • nabob21nabob21 Posts: 1,058
    Hi Felis. Do you mean that after I apply the suit to G8, I select G8 to apply the material or select the suit?
  • LeanaLeana Posts: 13,593
    edited December 2021
    You would select G8.
    A hierarchical preset is meant to apply changes to several different items parented to a figure at the same time, so you apply it to the figure which is the parent of all those items.
    Post edited by Leana on
    Thanks everyone. I'll give that a try.
