Converting G3 and G8 figures/animations?
DekeDeke Posts: 1,636
I can't find a good run animation for my G3 character. Is there a way to transform it to a G8 and use G8 animations? Or a way to transform a G8 animation to a G3 animation?
  • use the pose controls to move the arms up or down and legs in and out to use the same animations on both
  • DekeDeke Posts: 1,636
    Thanks. Yes, I guess that approach is what I'm stuck with. Was hoping for an easier solution.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,674
    edited December 2021
    well other ways are harder devil
    unless someone can create a one click script to do it
    to permanently fix an animation you can expand the graph editor in the advanced timeline for each of the shoulder and hip rotations and select all the keyframes on the axis you want to change and shift them up or down depending which side.
    then save that as a new pose animation
    certainly not easier but likely the way the people who sell the animations probably do it to create one for the other figure.
    I'll look into that. Currently the G3 character's legs pass through one another when a G8 animation is applied.
    under pose move the legs in out slider to fix it
    Yes, it's a bit of hip and a bit of thigh twist.  Thanks.
