Getting G81F back to default
Greetings,
I have somehow written over the G81F and she loads now with a character preloaded. Not a huge issue to remove it, but I would really like to know what I did so I can undo it permanently.
Any ideas on how to fi this? I have uninstalled and re-installed G81F twice now, and it doesn't appear to be the resolution.
Thanks,
V
  • The issue is the character, not the base figure - which one is it? If it's from Daz, how did you install?
  • ViallyVially Posts: 348
    edited December 2021
    The problem child is SC Julie, bought from DAZ and installed through IM.
    What I am finding is that when I start Studio up and load the Genisis 8.1 Base Female model... The Julie Character is set to 100% in the character/Real World morphs.
    So this is from a fresh restart of Studio, adding a new G81F base charactter, and BOOM! There's Julie
    Post edited by Vially on
  • First please report this to technical support so that ti can be fixed. In the meantime, if you load the devload version of Genesis 8.1 Female, select Edit>Figure>Zero>Zero Figure, then Edit>Figure>Memorise>Memorise Figure, and finally File>Save As>Support Assets>Save Modified Assets you should fix the issue pending an update.
    She's a G8 figure, so a quick fix;
    1. Open DS and load "Genesis 8 Basic Female" (to an empty scene)
    2. Right Click at Parameters Tab->Preferences->Choose "Show Hidden Properties" (part 3 zeroes only 'visible' dials)
    3. Right Click at Parameters Tab->Zero->Zero Figure (Zeroes the value of all the 'visible' dials)
    4. Right Click at Parameters Tab->Memorize->Memorize Figure (Sets the current value of all the dials as their default value)
    5. Edit->Save As->Support Asset->Save Modified Assets (Writes the changed default value to the morph files that were changed)
    When saving "Modified Assets" DS shows a dialog and asks for confirmation;
    "The following file(s) will be permanently modified:" - "Accept/Cancel" - Choose "Accept"
    Close DS and wait -> Open DS again and the issue should be fixed.
    Report her to DAZ, so she can be fixed for others as well.
    Perfect! Full resolution thank you.
    I am choosing not to report the character to support, as I am unable to tell if this is something I did to the G81F or not. (knowing me I probably did.)
    Anyway, thank you very much this has resolved the issue :D
  • Unless you had been tinkering in the File>Save As>Support Assets menu I doubt it was anything you did, and if it isn't a product issue then support will b ebale to confirm that there is nothing to fix.
