Low-Res Banana Slice Prop [Daz Studio only]
ModernWizardModernWizard Posts: 904
edited December 1969 in Freebies
Daz Studio only
Tested only in Daz Studio Pro 4.6 64 bit.
DESCRIPTION
If your digital models are hungry, serve them this low-res banana slice prop. Because it's simply
textured, it is best for mid-range and far shots, rather than super close-ups.
Tip: Use Daz Studio's Node Instances feature to put many banana slices on a bowl of cereal or a
banana split without using too many system resources!
LOCATION
After installation, find the Banana Slice in My Library > Props > Food > ModernWizard > Banana
Slice.
SOURCES
This freebie uses resources from the following:
Banana by gabi 91 at http://www.freeimages.com/photo/1072170
Fruit plate by larzip at http://www.freeimages.com/photo/921139
Superquadrics by Kawecki at http://www.renderosity.com/mod/freestuff/?item_id=74971
USAGE NOTES
Use for whatever purposes you like, commercial or non-commercial. Just don't repackage and call
your own. Have fun!
ABOUT ME
Find a repository of all my 3D freebies at the tacky trove:
http://tackytrove.blogspot.com
You can see my digital artwork, as well as my other creative pursuits, at my blog:
http://modernwizard.dreamwidth.org
If you do use any of my freebies in your work, drop me a line [ModernWizard at the Daz boards and
ShareCG, ModernWiz on Renderosity], as I'd love to see what you make. Thank you.
300 x 350 - 32K
