Merging files with dforce and keyframes
nagumo
I was wondering if anyone can help out with this problem: I have a file with with a dForce simulation applied that I am trying to import to another scene. I just want to import the last frame of the simulation file but I can't seem to figure out how.
If I delete the animation frames before merging, the deletion is done from last frame to first, taking the simulation with it. I can't import the dforce scene and keep the simulation because the scene Im importing too will also have its own animation sequence.
I'm trying to avoid manually deleting keyframes and I can't seem to get them all because of the complexity of the pose.
Any help would be appreciated!
I am running DazStudio 4.12
Post edited by nagumo on
You could hide everything but the simulaet item, or one of them, and export as OBJ, then load the other scene and import the OBJ as a new morph target for the model (Edit>Figure>Morph Loader Pro).
Sounds like a good idea. The scene only has one simulated item and the target scene I am merging to will only have camera movements animated, so the figure with the simulated item isn't moving.
I'll give that a shot, thanks!
Worked like a charm! Thank you
