FRONT PROJECTION MAPPING
jimmahbeejimmahbee Posts: 9
Hey everyone...ultimate NOOb here...is there a way to do front projection mapping onto a plane to catch shadows in DAZ? I can't seem to find anything on it. Or is there another way to go about catching shadows (I'm using HDRIs to light my scenes.)
THANX, Jim
  • Cris PalominoCris Palomino Posts: 12,959
    You can try this one.
  • skydatskydat Posts: 25
    You can also google a youtube tutorial by Carnite using the shadow catcher brick in DS4.7
  • jimmahbeejimmahbee Posts: 9
    Thanks so much...I'll give it a try...!!!!!
    edited March 2015
    I can't seem to get shadow catcher to work with HDRis . Can someone help?
    Post edited by jimmahbee on
    ONE AGAIN THE TOTAL NOOB HAS A DUMB QUESTION. Can't seem to get shadowcatcher to work with HDRi can anyone help?
    How are you loading them...
    If what you are using (let's say UberEnvironment 2) isn't in a shadow casting mode, then there's nothing to 'catch'.
    edited March 2015
    I merged the threads to keep the information in the same thread. Please do not split up thread on the same topic. What you can do is edit the title of the thread to say you can't get the shadow catcher to work in an hdri scene.
    Post edited by Cris Palomino on
    Sorry about that. ..yes I'm using uber environment 2. Is there another way to do HDRI lighting?
    HDRI will cast shadows fine, but you must remember to select ambient *with directional shadows*. Typically HDRI do not cast very strong shadows, they are mostly used for ambient light. To get a shadow add a distant light from the same direction as the sun in the HDRI.
    The other thing to check is that the HDRI map is either a TIFF (best) or a real HDRI file. I've seen some people trying to use jpeg. Jpeg are by definition not High Dynamic range, hence the reason for using TIFF and HDRI. Turn the intensity up also, and find a map with strong directional light. It does work I've tried it, but putting an distant light in will always create a stronger shadow effect.
    Thanks so much for the response! OK so you're saying Shadowcatcher will work with HDRI. I just need to remember to select ambient *with directional shadows*? k I'll try it.
    still isnt working. I dont see 'Ambient with directional shadows' I see occlusion with directional shadows' Is that what you're talking about?
    here's what it looks like if I add a directional light. If I add no lights there's no shadow at all.
    618 x 800 - 324K
