Female morphs
Sorry for repost but I did not find a clue
Hi
I try to clothe my G2F with different clothing bought by DAZ. All look fine till I morph the figure. The most mistakes can be reduce by a few morphs or x-away. But not all are gone.
For example, the Blazer, Shirt and Tie form the "Time for school" clothing pack have problems with the breast section when I morph them bigger or smaller.
Normaly the shirt have not visible separation between the breasts but after morphing them the separation is visible.
The Blazer outlines the breasts (after morphing) like a bra not like the normal overlaing coat
The Tie get a crush between the breasts which did not go away when the tie is moved out of the breasts.
This problems especially the shirt problem is in nearly all upper body clothing by G2F.
Thank you for your help
Manfred
The problem is that, in the absence of custom morphs for the shape you are using, the clothes mimic the changes to the base mesh - which is moving the breasts but not the sternum. Depending on which morphs you are using this may be worth a look http://www.daz3d.com/clothing-breast-fixes-for-genesis-2-female , or you can use DForms to adjust the clothes.
Thank you for your help.
Both work
Thank you
