Can't get Stephanie4 and Michael 4 to work
TheCastellanTheCastellan Posts: 711
Hi yas.
I had M4 and S4 for ages, and when I got my new compy, I wanted to add them to my Daz, and yet they won't work....A4 works, V4 works....but these 2 wont. Steph...KINDA works...the face looks like her, with messes up eyes, and the body won't morph. Any ideas as to why?
Here's some screen shots.
1920 x 1080 - 353K
1920 x 1080 - 301K
1920 x 1080 - 291K
1920 x 1080 - 305K
1920 x 1080 - 317K
  • nightwolf1982nightwolf1982 Posts: 1,320
    Powerloader will only work on the cr2 files that come with the Gen4 figures (Michael 4.cr2 and Stephanie 4.cr2 in this case).
  • Richard HaseltineRichard Haseltine Posts: 111,348
    There look to be several things wrong. The support folder would be \Runtime\Libraries\!DAZ\Michael 4 - presumably that is missing or misplaced (the Runtime must be in the actual folder selected as a Poser content directory, not in a sub-folder).
    You can't run the .dsb files directly - they should be in the same folder as the CR2, and will be run automatically when you double-click the CR2 from the Poser library folder. Those will appear as icons with a little scroll in the top-left corner.
    It may be easier if, instead of looking at a category folder, or using search, you find your content folder (whatever it is called, the one you installed to) in the Content pane then go to Figures>DAZ People - if things are missing there they weren't installed correctly, if they are present but don't work we can troubleshoot with at least some variables eliminated.
  • TheCastellanTheCastellan Posts: 711
    I downloaded them and installed them just days ago. Did not have problems like this before. o.O
    Have you tried using the actual content folders, not categories?
