How do the MM discounts work? Please Explain
KharmaKharma Posts: 3,214
How are the discounts calculated and on which items? Is everything in the New Mad, Still Mad, Related Mad, and Mad stores all 50% off if in your cart at the same time? What does the additional 10% apply to and when? Thanks to anyone who can explain how the discounts are working as my cart seems to jump all over and I can't tell where the discounts kick in.
  • BeeMKayBeeMKay Posts: 7,019
    You buy any one item of any of the mad categories, you get 40% discount on it.
    You buy two or more items from any of the mad categories, you get 50% discount.
    The higher discount is valid for newly mad and still mad category new releases.
    The higher discount is not valid for new releases and PC items from any other mad category.
    The higher discounts will not work on items priced 99cent or below.
    The 10% is an additional discount you got on all categories when buying/owning both the Darius&Monique; Pro bundles, but i think you had to buy them during the first three days of release? Not sure there.
    The 10% discount will not work on New Releases and PC-items that are not Newly Mad or Still Mad.
    I hope this will not make you even more confused. ;-)
  • KharmaKharma Posts: 3,214
    So I have River, The old Railway by DogZ, and Find your Mojo expressions all in my cart and only showing 30% discount on each one. shouldn't it be the 50% plus the 10% for having both bundles? Or does this combo of items not work? Do you have to have one new release? so confusing.....
    edited March 2015
    Now I put Pansies and River in my cart still only 30% discount....what is the trigger for the 50% as I thought all these categories gave 50% if you have at least 2 items.
    The small print does say any combo from these categories, now when I add SHI to the cart both pansies ( now at 5.38) and SHI (now at 5.83) are discounted 50% ( +10%...not sure) but not River ( still at 12.57). There seems to be a problem somewhere....
    Post edited by Kharma on
  • HavosHavos Posts: 5,711
    There is no trigger, just a matter of whether an individual item is entitled to a MM discount or not. That said there appears to a store glitch (not for the first time), in that some MM items are showing no additional discount (it could be all of them, I have not checked). When I add River, it is showing just a 30% discount, not 40% as it should be if he is alone in the cart, or 50% if another MM items is also in the cart. River is "Still Mad", so should be an MM item. You are probably best holding off until the glitch is fixed.
    Still the same issues, and I see no response anywhere from the higher ups so I don't know if it's working as supposed to or not. I see others have mentioned issues too, so guess I just won't buy anything for the time being until I find out for sure.
  • bad4ubad4u Posts: 684
    The sale is not working correctly today, which is why you have those problems. I still hope they get it fixed soon...
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,832
    Well you just negated your small errors, big errors and upcomming humungous errors threads with that one little word
    soon :lol:
