experiencing Save corruptions
Angel_2232633Angel_2232633 Posts: 1,204
I'm experiencing a high volume of saved scene corruptions.
LOG File says
Json Parser (377910,8): Unhandled exception during parsing.
Error reading file, see log for more details.
I use Daz 4.7.0.12 but it also has Reality 4.07 data.
425 x 111 - 16K
  • TheWheelManTheWheelMan Posts: 1,014
    Your hard drive isn't going bad, is it?
  • Angel_2232633Angel_2232633 Posts: 1,204
    edited March 2015
    I wouldn't be able to tell you that. Don't even know how to check. But I doubt that's the issue...
    On launch when load lux I get this warrning.
    [2015-03-01 12:10:55 Error: 2]There was an error while checking the size of file /AppData/Roaming/DAZ 3D/Studio4/temp/d89.png'
    [2015-03-01 12:07:22 Error: 2] Error hashing file /AppData/Roaming/DAZ 3D/Studio4/temp/d89.png'
    [2015-03-01 12:07:22 Error: 3] Unable to open image file /AppData/Roaming/DAZ 3D/Studio4/temp/d89.png'
    Post edited by Angel_2232633 on
  • Richard HaseltineRichard Haseltine Posts: 112,053
    The temp folder should be empty anyway, it sounds as if there may well be a problem with your discs if you are seeing that and bad saves though occasional problems with saves and with left-overs in the temp folder are possible without hardware issues. You might try manually emptying the temp folder with DS closed and relaunching.
    edited March 2015
    Nope, that didnt do it.
    I've noticed it happens more frequently when I have Jeps male gens for genesis & m4 in the scene.
