main menu mixed up
j_stnkj_stnk Posts: 205
hello!
i'm wondering why my main menu and sub menus are all mixed up from the original order? my computer just upgraded to win 8.1 and since then weird things are happening. when i use reality4 and lux or even 3delight my windows navigator stops working and task bar icons switch apps. or double beside each other. anyone have anything like this going on with win 8.1? i wanted to run a script to correct dup ids and "script" was gone in the main menu bar. i looked at the log file and saw it was win 8.1 but no service pack installed. what are the requirements for daz4.7 to run? humph.... thanks i can still use the program but everything is messed up.
  • Richard HaseltineRichard Haseltine Posts: 112,021
    Try reloading your layout, Window>Workspace>Select layout. If you hadn't saved your old layout that won't restore the Scripts menu, but you can do that manually in Window>Workspace>Customise - your custom actions are in the first group on the left, there is a tab for menus on the right where you should expand Main Menu, right-click, Add item and create your Scripts menu, then drag the commands across. Though by now I'd hope that the need for the Fix Duplicate IDs script had largely ended.
