Ultra Scenery Toolbox Suggestion
https://www.daz3d.com/ultra-scenery-toolbox--volume-one
I like this a lot. It's super useful and easy to use. But there is something I'd like to see in the next version, if there is a next version.
I often put the camera close to the ground and for this reason it would be useful to be able to do multiple passes with the round marker. I'd like to mask out trees in a large radius, but flowers and tall grasses only in a small one, right in front of the camera.
  • barbultbarbult Posts: 27,608
    You can do that already. Just add multiple round markers scale each one to the size you want.
  • lou_harperlou_harper Posts: 1,163
    It doesn't work if the markers overlap. The bigger one overrides the smaller one.
    edited November 2021
    @lou_harper You might not be assigning the correct layers to each marker in the UST Mask Builder. Don't assign the grass layers to the trees marker. Here is an example. You can see how I assigned all trees to the large marker and all the small stuff to the small marker. (BEFORE running UST Mask Builder, I renamed my markers in the Scene pane, to make it easier to remember which marker I intended to use for which purpose.)
    1028 x 589 - 80K
    816 x 624 - 63K
    2000 x 2000 - 2M
    Post edited by barbult on
  • TugpsxTugpsx Posts: 921
    Is this still worth getting since Volume 2 is out and has a lot more features? Are there any overlapping features or features i would miss just getting volume 2?
