Generation 3 and 4 morphs (including Morphs ++ etc.) into Genesis 2?
FauvistFauvist Posts: 2,291
I know it's a logistical nightmare, but is there some way to load the morphs for the previous generation figures into the Genesis 2 figure? I know you can load a full body shape, the UV, and AutoFit, but what about all the various morphs created for the older figures? I can do it with Genesis, but how do you do it with Genesis 2? Is there a workflow, product, or tutorial?
Thanks!
  • CrescentCrescent Posts: 335
    Dimension3D created a product called GenX which recreates morphs from older figures for Genesis and Genesis 2 (with an add-on).
    http://www.daz3d.com/catalogsearch/result/?q=genx 2 will get you the main product and add-ons for it. (The base product is generation 4 to Genesis.) I've been pleased with the results.
    Cheers!
    Moreover, Slosh mentioned working on A3 and H3 - both shapes AND autofit clones, even UVs. Maybe they will show up during MM.
  • FauvistFauvist Posts: 2,291
    I've been able to get Gen 3 and 4 into Genesis, but I don't know how to get Gen 3, 4, and 5 into Genesis 2. Does that product inject all the morphs from those 3 previous generations, or just the "full body morph" giving you the shape of the base character?
  • HavosHavos Posts: 5,711
    edited February 2015
    As long you have the genesis 2 extension (http://www.daz3d.com/genx2-addon-for-genesis-2), then transferring morphs from gen 3, 4, or even Genesis 1 works the same way as when you moved the Gen 3 and 4 stuff to Genesis 1. Just load in the source the same as before, but select either Genesis 2 Male, or Genesis 2 Female as the target.
    Edit: The first time you transfer any gen 4 morph to G2M or G2F GenX will create a V4 morph (or M4 if that was the source) as well. Then, after transferring your character, you have to dial in V4 as well as the character in order for the character to look the same as it did on V4.
    Post edited by Havos on
    Thanks for the information! I finally found the tutorial for Gen X2 http://d3d.sesseler.de/store/dazscript/genx/GenX2.pdf
  • almahiedraalmahiedra Posts: 1,374
    I can't remember how I did it, but I tranfer V4 morphs ++ to G2F in batch with D3D's GenX. I follow manual information and get all morphs perfectly ordered with few clicks.
    667 x 667 - 327K
    190 x 259 - 9K
    gilikshe said:
    Thanks so much for the link!
