OSO FOX
multiple fails in rendering fur in DA 4.15 with errors; no response to 2 disappearing tickets requesting help and and no response to 3rd one that I actually printed save the ticket # to a pdf(attached), and today, a submission for refund of Dog 8 packages since I can't get the fox to complete with fur would NOT submit (attached) and last but not least I made a request for help with all 3 in here and there was no way to post it.
Someone who knows how, please submit these to DAZ so I can at least get a refund and IF anyone has an idea as to why the fur will not render, please enlighten me.
  • Attachments removed, please don't post your tickets publicly - especially as it shows your email address. Did you receive an auto-reply? It looks as if you were not logged in, so the details may not have matched (Zendesk doesn't pick up the log-in from the store unless you click the Sign In button)?
    So - is the hair showing in the Viewport in preview? What are your render settings? What happens when you try to render the fox?
  • nonesuch00nonesuch00 Posts: 18,863
    dForce or Strand-Based Hair (SBH) Fur will not render in 3DL, Scripted 3DL, Multipass-OpenGL, or Viewport (aka Filament (aka Viewport Render Engine dropdown selection + Filament (PBR) Drawstyle chosen in the actual viewport)) render engines or (maybe) in some iRay Preview situations depending on hardware and RAM. Fur will render in a full iRay render though, including the OSO Fox which I just rendered that way.
  • GordigGordig Posts: 10,785
    edited November 2021
    That's not true at all. dForce hair will render in 3DL. You don't have as many surface settings in 3DL as you do in Iray, and I believe you can't use an image for creating varied coloring, but it will render. This is without even applying any 3DL shaders.
    800 x 800 - 191K
    Post edited by Gordig on
    The original Garibaldi Express, from which the Strand Based Hair system derives, was pre-Iray.
    Oh, thanks for clearing that up. I though those were just openGL placeholder strands because they were so flat looking.
