Iray Server doesn't render HDRI background
Hi!
I was just testing iray server and even though i can see previews have the hdri background, the result render does not. I attach files.
Any idea what causes this?
Thanks!
1920 x 1320 - 5M
800 x 550 - 384K
  • QuixotryQuixotry Posts: 919
    Do you have Draw Dome turned off or on in your render settings? It should be on if you're using the HDRI as a background as well as the light source. Just a thought. Sometimes I turn it off and on as I make the scene, then forget to turn it on before I start the render.
  • GordigGordig Posts: 10,822
    If Draw Dome were off, it wouldn't show in the preview, though.
  • Ok guys i figured that out!
    It appears daz sends pixel type as RGBA - so when i delete Alpha channel from Photoshop, i get my background. (From Layer -> Layer Mask -> Selecting Channel and deleting Alpha)
    I guess there should be a pixel type selection in Daz before sending it to iray but there is none, however u can edit it over iray server before rendering from the queue.
    Thanks for the comments!
  • Chloe_MChloe_M Posts: 5
    edited September 2022
    Seems this issue still exists in Daz3D today, I've setup an iRay Server but by default it outputs as RGBA unless you change the settings per file in the queue manually first
    Now I've installed Photoshop (free trial for the moment) but I can't figure out how you remove the alpha....
    In channels in Photoshop all I see is this;
    295 x 175 - 12K
    Post edited by Chloe_M on
  • @Chloe_M, Try this using GIMP, this is a free program.
    Get it from https://www.gimp.org/
    Load any picture and edit and remove the Alpha Channel of the image.
    Hope this helps.
    3835 x 2031 - 250K
  • drawfleshdrawflesh Posts: 19
    Well, this doesn't solve it for me. In PS I can't remove any alpha layer (not easily it seems) and in Gimp when removing the Alpha layer, it simply makes the background white. This is not a solution. Could it be something with the color range?
    It is just weird...
  • Richard HaseltineRichard Haseltine Posts: 111,939
    Alpha layer? It's an alpha channel, which should mask parts of the image or be available a channel that can be loaded as a selection and used to create a mask or copied directly to a mask, depending on how the application works..
  • TotteTotte Posts: 15,246
    Default in IrayServer when the wanted format has alpha (like .png), is to make that transparent. Just set the format to .jpg before uploading to the server (or change it on the server edting the render job)
