Quick Question
404nicg404nicg Posts: 270
I know Genesis uses v4 UVs so V4 textuers work on the figure...what about V4.2?
  • fixmypcmikefixmypcmike Posts: 19,713
    V4.2 uses the same UVmap as V4.
  • 404nicg404nicg Posts: 270
    Thank you very much! One more quick question though lol..
    I have a texture for a Stefanie 5 character...what all do I have to buy in order to be able to use that on Genesis?
    Do I actually have to buy V5 and then buy Stefanie for v5?
  • Scott LivingstonScott Livingston Posts: 4,352
    edited February 2015
    Depends on the character. Some characters for Stephanie 5 require that you actually own Stephanie 5 to use the skin (in other words, they use S5 UV maps). You shouldn't need to own V5 (unless the character uses Victoria 5 UV maps, and I'm not aware of any Stephanie 5 characters that do).
    Post edited by Scott Livingston on
    Wow you know what , this whole time I thought that in order to get Stephanie5 or Aiko 5 or anything like that you had to get Victoria5 first and then branch off from there..but all you need is genesis. Thanks alot for clearing that up for me.
    No problem...and you're not too far off, as that was the case for Generation 4 characters...both Aiko 4 and Stephanie 4 require Victoria 4.2.
    But with Genesis, Genesis itself is the base figure, so the "iconic" characters like Aiko 5, Freak 5, David 5, etc. don't require any other purchase. The same is basically true with Genesis 2: the base figures are Genesis 2 Female and Genesis 2 Male, so you don't need to own V6 or M6 to use characters like Stephanie 6, Darius 6 etc.
