Modifying and Saving a Dress for a new figure in Daz - Solved
3dOutlaw3dOutlaw Posts: 2,481
Here is what I have done:
  1. Load an old V4 Dress on G8F
  2. Fit it to G8F using a Clone
  3. Apply Smoothing and SubD
  4. Apply 3 dForms
  5. Hidden the lower section of the dress by making it transparent
Here is what I want to do:
  1. Remove the hidden Geometry from the dress
  2. Turn the dForms into Dials
  3. Save the Dress as a new Figure for G8F
Not sure if it is possible, and if so the proper or best order to do them in.  Also don't know how?  cheeky  Any guidance on the last 3 would be appreciated!
Post edited by 3dOutlaw on
  • LeanaLeana Posts: 13,504
    IIRC geometry editor tool should enable you to actually remove polygons.
    Save it as a new figure asset.
    Once you've saved your new dress: Export the dFormed dress as obj. Load a new copy of the dress without the dForms, then use morph loader to load your obj as a morph, and save the new morph as a morph asset.
    Perfect, @Leana !  That all worked, thanks so much!  laugh
