does daz studio work with intel graphic 4000?
i have a old core i5 2.5GHz 4GB ram laptop that running win7 .it has intel graphic 4000 graphic card.
 can i use this laptop to run daz studio?
but i have Bluescreen of death problem while
  • You should be able to "Work" in ds, but you're going to be seriously limited by that ram.
    You'll be hitting the 4GB just in scene construction very quickly and you'll be limited to cpu rendering only, no gpu acceleration, which will probably switch to virtual ram and be really, really slow.
  • nonesuch00nonesuch00 Posts: 18,882
    edited November 2021
    Yes it does. You have to CPU render, I recommend restricting the CPU Affinity for renders to be 1/2 to 3/4 of the CPU cores available (in the Advanced IRay Render Settings). dForce also works on Intel HD Graphics 4000 GPU.
    You probably want to up the RAM to 16GB if the computer supports it. Also upgrade to Windows 10 if you can as I doubt your computer is TPM 2.0 compatible.
    If you do have to stay at 4 GB RAM try not use SBH or dForce hair derived from SBH. Or try not to use LAMH hair either. With 16GB, go for it, it just takes patience.
    Post edited by nonesuch00 on
