Problem with RiverSoft G3F to G8F Converter - Any way to fix?
Hi,
I've been converting my G3 characters to G8 using RiverSoft Art's Character Converter from Genesis 3 Female to Genesis 8 Female https://www.daz3d.com/character-converter-from-genesis-3-female-to-genesis-8-female and generally it has proved very successful, but I'm having problems with one character, IST Cassiopiea https://www.daz3d.com/cassiopeia-for-genesis-3-female as the textures just go crazy on the converted figure (see attached image.)    I've converted another character from IST with no trouble so I'm not sure if the problem is with the converter or the character.   I've tried reconverting the character but it comes out the same.   Does anyone know a way to fix this?
Thanks in advance for any help.
Lossow
600 x 800 - 367K
  • margravemargrave Posts: 1,822
    The UVs aren't converting properly. Those white areas are the gaps around the texture maps.
    Go into the surfaces tab and check what UV Set the figure is using, and also if the original has custom UVs.
  • 3dLux3dLux Posts: 1,231
    It's also possible to save G3F Cassiopea's skin as a Material Preset then apply that preset to the G8F version.  I've done that with my G8Fs from G3F conversions because I use shader presets like Anagennesis which changes the texture settings.
    Transfering skins as Material Presets only works if the source and target share the same UVs, like G3 and G8.
  • MelanieLMelanieL Posts: 7,863
    Cassiopea uses the V7 UV maps, not the Base Female. You need either to convert manually (try these instructions) or use a product like this one that adds V7 UV set to G8F.
