Creating Morphs in Zbrush problem with DS 4.15
Have used previous versions of DS to export the G8F mesh as obj and then import to Zbrush. Create changes in Zbrush then export as obj. Importing back into DS with Morph Loader. Now with DS 4.15, it does not import back because the points/vertices count don´t match. Any ideas?
Are you sure you exported only the figure (no brows or lashes for example) at base resolution?
You got it. I ran across a tutorial that mentioned deleting the eyebrows/lashes, but it wasn´t worded like it was an absolute necessary step. But the difference in the vertex count was so small that I figured that might be the cause of the problem. And so it was. I guess the previous editions of DS did not automatically load the brows/lashes. Thanx for the response.
The DevLoad figure doesn't have the add-ons.
