I want to write a DIM filter... [Update: got my path filter working, recipe inside]
SkirikiSkiriki Posts: 4,976
So, I noticed that something is missing from the filters in "Installed" section of DIM: sort by install directory. (Since I'm a freak who has also sorted content according to general content type.)
Basically, I need to figure out if there's a way to ferret install path, and then have DIM sort according to it. This would make some operations easier.
Edit: Never mind, I seem to be a moron today, as I just stumbled upon "Path".
Post edited by Skiriki on
  • SkirikiSkiriki Posts: 4,976
    For the record, if you want to make this script too, head over to wherever your DIM keeps 'Filters' folder.
    In my case, it is: C:\Users\Public\Documents\DAZ 3D\InstallManager\Filters\
    There, make a directory called "Path".
    Then make a .txt file, named like Creatures.txt, assuming that you have a folder named "Creatures" where you save non-humanoid-based figures, like dragons and dinosaurs and animals and whatever.
    Put in this to the text file: path::rx::ci::^.*Creatures$
    Save and test in DIM.
    Replace "Creatures" with whatever install directory name you use for things, like "People" or "Nature" or whatevs. You can refine this with a better regexp, too, but this seems to do in a pinch and I really don't wanna overthink too much, regexps are famous for "You got a problem. You decided to use regexp. Now you have two problems." kind of deal.
  • Richard HaseltineRichard Haseltine Posts: 111,769
    You can also type the text in DIM, to make sure it's working, and then save a preset from there by clicking the magnifying glass icon next to the text box and selecting Save Filter from the menu.
    Yup, I just had a regexper tool at hand, so that was pretty much the fastest way for me. But yeah, that works too.
