User Scene file not working or responding
Bunyip02Bunyip02 Posts: 9,345
Hello all
I am able to load other scenes, but everything in my User Scene file is not responding.
Am about to try the zip file method opening as a zip file manually in the folder by Windows Explorer.
Otherwise any ideas ?
Was trying to open my old DragonBoat scene to do some more work, can-not access my spaceship scene from one of the previous challenges either.
Regards, Bunyip
  • Bunyip02Bunyip02 Posts: 9,345
    Update:-
    Zip file method was no joy.
    So I copied my .car file of the DragonBoat and placed it into a new folder in the Scene file.
    I then loaded that file into Carrara via the RHS folder icon method.
    After that I was able to reload the Dragonboat file into Carrara.
    It took a while so it may be one of those background updates slowing the computer down.
    Still having no joy loading via User-Scenes.
    Will try again tomorrow and let everyone know whats happening.
    Good news is that the Plan-B worked.
    Regards, Bunyip
    1359 x 767 - 336K
    Could it be some kind of OS permissions issue?
  • mikael-aronssonmikael-aronsson Posts: 607
    edited February 2015
    Did it crash ?
    Carrara can take a silly amount of time to load some scenes so if it just hang, you may not have waitied long enough ;o)
    (Maybe the directory is checked by antivirus software ? this can cause nasty slowdowns, but usually not on reads)
    Post edited by mikael-aronsson on
    Hello EP and Mikael
    I opened up the User-Scene file and let it run overnight while I slept.
    It eventually opened but it took hours to do so.
    Previously it might have been 5 to 10 minutes max to open a large file on my PC.
    When I went to then close it, it then refused to close.
    I did have a file crash during my first challenge that I participated in.
    Will do a thorough spring clean and see if that sorts out the problem, if not I'll throw a support ticket in for it.
    Was working fine when I did some error checking for a PITA problem for DADA in the challenge just gone.
    Regards, Bunyip
    sounds like a pain, what happens if you try to import it into another scene?
    Hello Headwax
    Have not tried to import it into another scene, but when I checked file-sizes one of the files had a size of 4 400 000 kb when all of the other similar files had a size one-tenth of that.
    I suspect that file became corrupted some-how.
    Good news is that the DragonBoat scene is now working fine and loads in about 20 to 30 seconds.
    Glad I did not lose that one.
    I'll still do a spring clean this weekend, was planing to do one before, more reason to now.
    Regards, Bunyip
