I'm Stuck: Easy Environment, Top of the World
mwokeemwokee Posts: 1,275
Just purchased Easy Environment/Top of the World. Seems to have installed OK. problem is, I can't find it in my product library.
On the product page there is a link with some tips. All it says is load it and render it in Daz.
Well, that's my problem. I can't figure out how to load it. Should it be in the product library? Or do you load something else first and then apply the skybox?
Thanks
  • Steven-VSteven-V Posts: 727
    I don't have it but try looking in the alphabetical part of your product library under either E (for "easy") or T (for "top of").
  • mwokeemwokee Posts: 1,275
    Done that, looked for Easy, Environment, Top, World, and used the SEARCH too.
  • kaotkblisskaotkbliss Posts: 2,918
    edited February 2015
    The product library in the content pane uses the exact name as here on the website under your account "my products"
    I was looking for Mikaella (sp?) but after checking my products here on the site, I found it under LY Mikaella.
    *edit*
    I'm assuming it's this piece? http://www.daz3d.com/top-of-the-world
    In which case it should be under T
    If not, check your Dim to be sure it was actually installed.
    Post edited by kaotkbliss on
    The files appear in "Content Library > Poser Formats > My DAZ 3D Library > Props > FM_EasyEnvironments > TopOfTheWorld".
    There are icons labeled "Scene & Skybox 1" and "Scene & Skybox 2" to load the scene with one of the two different backgrounds. Then go to "Content Library > Poser Formats > My DAZ 3D Library > Light > FM_EasyEnvironments > TopOfTheWorld" to load the light set.
    Strange... watched it install OK. Nothing. Tried reinstalling, it shows up now.
    Thanks for the help.
    Post edited by mwokee on
