Help with chest morph and clothing
Hello, I created a morph with zero breasts, because most of them seemed to me that they were bad with clothes.
the problem is that mine, when I apply it, it looks like a ball in the center.
Could you help me?
The morph has already been saved as a morph asset
So you have the morph in the figure but not in the clothes? When DS projects a morph into clothing it looks at maintaining the relationship between nearby points on the clothing and the figure - because your morph presumably doesn't have much effect on the sternum it leaves the sternum area of the clothing alone, and in this case the clothing was more offset from the skin there than on the breasts so you are left with a bulge. The only real way to fix this is with a custom morph in the clothes to match the morph on the figure, though you might try a smoothing modifier.
