daz font size
fairyfantasticfairyfantastic Posts: 116
hi all ive just bought a new lappy and installed daz 4.7 and the font and words are very small is there any way to change this but every thing else on the new lappy is fine and right size but not daz
    edited February 2015
    are you talking about DAZ 3D the site or DAZ Studio (DS) the program?
    Post edited by Chohole on
  • fairyfantasticfairyfantastic Posts: 116
    sorry should of said dazstudio
  • Richard HaseltineRichard Haseltine Posts: 111,430
    If it's a new install you will be using the Darkside style, which has the smallest fonts. Going to Window>Style>Select Style and switching to Main Street will make things a bit bigger, but there isn't a user-accessible way to change the font size (you'd have to make a whole new interface style, which would be a pain at best).
  • linvanchenelinvanchene Posts: 1,386
    Just to make sure:
    Does your laptop have a Full HD resolution of 1920x1080?
    Or is the resolution higher?
    3200 x 1800
    3840x2160
    Some new laptops feature such 4K ready / UHD resolutions.
    4k is not nessecarily needed while working on the laptop. But 4K support is needed when you want to stream a 4K presentation from a laptop to a 4k beamer or monitor.
    The issue could be that until windows 10 arrives most software will not fully support 4k resolutions.
    There may be some automatic scaling but this will in most cases yield blurry interface elements unless the software fully supports scaling the UI to higher resolutions..
    So IF your laptop comes with 4K resolution you could just scale it down to 1920x1080 to have less issues until all software have a 4K ready UI.
    Post edited by linvanchene on
    the resolution is set at 1920x1080 my partner did try different res but nothing changed it thing is its only happening in studio my hex if fine my internet explorer if fine to
