Problems with Tyler HD
When applying the materials for the Tyler character, the genital materials don't quite match the body. There is a separate button called "apply when using the genitals" but when you apply it, it only affects the hips! So now the gens match the hips ok, but the hips don't match the rest of the body!
Anyone know how to fix this?
I think this is because you are mixing the two shader presets that are provided for Tyler. The icons both look the same, but there is a HSS preset and an AoA preset, and you can't mix them. Select the Info tab at the bottom of Smart Content and click (once) on the icons to see which they are from the Path info. Decide which shader you want and make sure you use the same for main body, the genital figure and the Hip Genital.
Alternatively, load the textures from Content Library where the shader sets are in different folders and so are easier to identify. You can easily get there from Smart Content by right clicking a texture and selecting Show in Content Library.
The Hip Genital preset is for the body and it does only change the hip region texture.
you are quite right!
