dforce: No collision with ground!
So Im trying to use this product: https://www.daz3d.com/dforce-laundry
And I want the clothes to be laying on the ground like someone dropped them but somehow they arent colliding with the ground and they just fall through it and they fall and fall and... "visible in Simulation" is On and I tried to use the collision from the smoothing modifier but Ive read that this doesnt change anything for dforce. I tried to drop them on a character and this worked without a problem somehow.
I rarely use dforce and this is really confusing to me. Can someone help? Thanks.
What are you using as the ground? if the mesh is too open then things can indeed fall through - if necessary add a primitive plane with a fair number of divions at floor level to act as a catcher, but turn off Visible In render in its Parameters so it doesn't clash with the real floor..
Yes! This was the solution. Thanks man!
