How to save V4 default skin without purple . . .
Daniel BarnettDaniel Barnett Posts: 389
I found how to change V4's figure without bikini but how do I over write the default figure so I don't need to do this change every time I use her?
Thanks
dbb
  • frank0314frank0314 Posts: 15,116
    Preferences / startup tab
  • Daniel BarnettDaniel Barnett Posts: 389
    That's not how to over write default skin! You gave me how to change the startup settings!?!?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,835
    In DAZ studio you can set a texture preload in powerloader
    If you are really keen you could edit the path in her cr2 using notepad
    added for example
    ":Runtime:textures:DAZ:Characters:MilWom:V4:V4SmplFaceM_BKN.jpg" in notepad change path to texture of your choice
    need to do for all
    added for example
    need to do for all
    Thank you ! 1 - I think I can work with this info.
