Search Function
Bruce CookBruce Cook Posts: 34
Hi:
I found the search function on DAZ 4.6 quite helpful. The same function is included on DAZ 4.7 Pro, but I cannot get it to work. Is there something I have to do to get it set up properly? I would be most appreciate for any help or suggestion. Thanks!
    Nothing has changed as far as I know in 4.7.
    The search function always relied upon CMS running as it uses the database. Are you still using CMS/Valentina, or did you upgrade to the new PosetgreSQL db system?
    If CMS is not running, you will not be able to see any content in Products or Categories either, and Smart Content will not work. If you are still on CMS, go to Start > All Programs > DAZ 3D and start CMS from there and see if that fixes it.
