Is it possible to mirror a model?
I am wondering if it is possible for DAZ Studio to mirror a model.
For example, let's say I have a robot arm I want to use on a figure (i.e. Genesis). I want my cyborg to have the robot arm as his *left arm*, but the robot arm I have is of a *right arm*.
Would it be possible for me to mirror the right arm model in DAZ Studio and use it as a left arm?
Also, would textures still work on a mirrored model? If I mirror a hairstyle, would I end up with a wacky looking case of bed-head because the textures no longer match? Would the company logo on my robot arm be stuck in the armpit instead of on the shoulder because of the way the texture is applied?
    You can mirror poses in DAZ Studio, but mirroring geometry would probably require a modelling program of some sort.
  • LeanaLeana Posts: 13,657
    See this thread on the same subject: http://www.daz3d.com/forums/discussion/49718/
    There's and utility available to convert Poser-format items, for Genesis content you can try using SickleYield's method.
    And yes, textures should still work, UVs will be mirrored too. So if you have text it will probably be inverted...
