Various Age Bob - Skullcap spider veins
I've had this product for awhile but never noticed this before, probably as I never got in this close.
At first I thought is was an 8.1 character problem, but after testing I see it on Gen8 characters too. Also seeing in current release as well as Public Beta.
Any ideas?
1920 x 1080 - 398K
1920 x 1080 - 566K
1920 x 1080 - 450K
  • charlescharles Posts: 866
    edited October 2021
    This is an issue with your cap for the hair, you need to switch to smoothed view and you will see how the haircap is intersecting with the forehead, you need to use the parameter sliders (even the greyed out ones if there is no standard ones) to make it to where the haircap is not intersecting with the forehead.
    Some will suggest drilling to the head node and exapnding or shrinking it, you can do that and that sometimes works, but it's best to tweak the exact spots. You can also use meshgrabber to tweak it out.
    Post edited by charles on
  • marblemarble Posts: 7,500
    This happens a lot. I usually just expand the hair slightly so that the skull cap doesn't intersect withh the actual head.
  • FrinkkyFrinkky Posts: 388
    edited October 2021
    As others have said. the cap mesh is intersecting with your character's forehead. As this is an OOT hair, it will have a forehead depth morph; 5-8% will usually suffice. In addition (or instead of, ymmv) you can also add a smoothing modifier to the hair itself - it should automatically add the parent character as the collision target.
    Post edited by Frinkky on
  • Doc AcmeDoc Acme Posts: 1,153
    OK, thanks folks.  I'll look for that param. Never needed it before.
