Duplicate formula found - Beulah and Expressions for Genesis 8.1 Female
Hello
I just Bought the PA Beulah and Expressions for Genesis 8.1 Female (Product Sku: 81681)
I have a lot of "Duplicate formula found" when loading an asset pre-saved:
here the log file (attached) and some example
2021-10-21 17:22:55.079 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(7206): Unsupported formula: /data/DAZ%203D/Genesis%208/Female%208_1/Morphs/P3Design/Every%20Day%20Emotions/P3D%20Amused.dsf
2021-10-21 17:22:57.104 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(7230): Duplicate formula found linking xOrigin & Ergou Beulah Smile in /data/DAZ 3D/Genesis 8/Female 8_1/Morphs/Ergou/Beulah/Ergou Beulah Smile.dsf.
2021-10-21 17:22:57.104 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(7231):     owner: Genesis8_1Female
2021-10-21 17:22:57.104 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(7232):     output: head:/data/Daz%203D/Genesis%208/Female%208_1/Genesis8_1Female.dsf#head?center_point/x
2021-10-21 17:22:57.104 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(7233):     input: Genesis8_1Female:/data/DAZ%203D/Genesis%208/Female%208_1/Morphs/Ergou/Beulah/Ergou%20Beulah%20Smile.dsf#Ergou%20Wen%20Smile?value
2021-10-21 17:22:58.005 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(7230): Duplicate formula found linking yOrigin & Ergou Beulah Smile in /data/DAZ 3D/Genesis 8/Female 8_1/Morphs/Ergou/Beulah/Ergou Beulah Smile.dsf.
2021-10-21 17:22:58.005 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(7231):     owner: Genesis8_1Female
2021-10-21 17:22:58.005 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(7232):     output: head:/data/Daz%203D/Genesis%208/Female%208_1/Genesis8_1Female.dsf#head?center_point/y
2021-10-21 17:22:58.005 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(7233):     input: Genesis8_1Female:/data/DAZ%203D/Genesis%208/Female%208_1/Morphs/Ergou/Beulah/Ergou%20Beulah%20Smile.dsf#Ergou%20Wen%20Smile?value
2021-10-21 17:22:58.949 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(7230): Duplicate formula found linking zOrigin & Ergou Beulah Smile in /data/DAZ 3D/Genesis 8/Female 8_1/Morphs/Ergou/Beulah/Ergou Beulah Smile.dsf.
2021-10-21 17:22:58.949 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(7231):     owner: Genesis8_1Female
2021-10-21 17:22:58.949 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(7232):     output: head:/data/Daz%203D/Genesis%208/Female%208_1/Genesis8_1Female.dsf#head?center_point/z
2021-10-21 17:22:58.949 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(7233):     input: Genesis8_1Female:/data/DAZ%203D/Genesis%208/Female%208_1/Morphs/Ergou/Beulah/Ergou%20Beulah%20Smile.dsf#Ergou%20Wen%20Smile?valu
txt
txt
duplicate formula found.txt
367K
  • Although I usually say that Duplicate Formulae issues are a clash between two products that seems less lielly here, given the names of one of the properties in the formula - I'd guess it's either a product error or possibly the PA reused the files when making another character you have installed and in hand-editing the files failed to chnage the name (the latter would be less likely to be caught in testing). I would open a ticket to report this to Daz, though you might try uninstalling any other ergou characters you have, one by one, and see if the error goes away - if so then you have found the actual problem product.
  • Well I uninstall the Pa Beulah and Expressions for Genesis 8.1 Female, for now. I was assuming posting on the forum the creator would be alert, since i didn't find the PA post on the forum
    but thanks, I'll open a ticket
  • I literally ran into this about 6 hours ago and fixed it myself. FYI / Note, this is considered an 'unsanctioned' fix, but it's worked for me a few times in the past at a 100% success rate (for both content at rendor and here)
    1.) Batch convert the file and decompress it. (found in Daz studio under window -> panes (tabs) )  Make sure to overwrite the original file.
    2.) Open in notepad.
    3.) Use the Replace feature under Edit since there are literally hundreds and replace all Ergou%20Wen%20Smile with Ergou%20Wen%20Smile1 Will take about 10 seconds.
    4.) search in the top area for "label" : "Ergou Beulah Smile" and change it to this "label" : "Ergou Beulah Smile1"  Do this manually.
    Save. relaunch Daz studio.
  • BejaymacBejaymac Posts: 2,008
    Not the first time one of Ergou's products has triggered Duplicate Formula errors, Naoko for G8F had badly done eyes closed correctives, and they were triggering DF errors with Rin's badly done eyes closed correctives.
    Richard it still is a case of two products with the same asset ID's, "Ergou Wen Smile" is the ID when in this case it should be "Ergou Beulah Smile". As a result every formula has "Genesis8_1Female:#Ergou%20Wen%20Smile?value" instead of "Genesis8_1Female:#Ergou%20Beulah%20Smile?value".
    Now I don't see a Wen character in their store (just a hair), so it's either a removed product, one sold elswhere, or a bunch of copy/paste expressions in some of their other products.
    Yes, I did mean it might be a sungle product error if soemthing had doubled up in the editing or it might be that they copied the .duf ile, in whole or in part, when setting up another chararacter and ended up using the same names so that it would be a two-figure clash. Sorry for any unclarity.
  • UnspecifiedUnspecified Posts: 19
    edited October 2021
    I have the same problem, ever since I purchased and installed Ergou's Buelah every one of my 8.1 characters will not load without generating the "Duplicate Formulas Found" message.
    Post edited by Unspecified on
    Yes, because it has nothing to do with whether either of the morphs involved are used (non-zero) - they still have to be read and their links added to the figure's data so that DS knows when to load them due to their having gained a non-zero value.
    Well, I think you just saved me hours of time and an uncountable number of perfectly innocent hair folicles. Thank you for sharing.
