Foot-plant plugin?
I am wondering if there is a product for Daz that will take a general pose I have created and adjust it to plant the feet(or foot) on the ground and/or balance the figure out to make it look stable?   I can manually do this, but always end up messing up the pose's other elements, and rarely plant the feet so that they aren't poking though the ground.   I am fairly good with the "active pose" tool,  (I wish the gizmo would stay on.)
  • margravemargrave Posts: 1,822
    edited October 2021
    There is a free script called mcjAutolimb2015 that will sort of do that, however what you're looking for is called inverse kinematics and it's a major sore spot for many Daz users that this program, which is allegedly suitable for animation, doesn't have a proper IK system to make good animation with.
    Post edited by margrave on
  • DaventakiDaventaki Posts: 1,624
    There maybe others out there but have you looked at Ultimate Pose Master?  It does quite alot but im not sure if it does specifically for what your asking.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,722
    Pilning WalkIt which some use might help, it's a thirdparty plugin so I cannot link it, I have never used it but it's actually an animation tool where foot prints are placed for the feet.
  • juvesatrianijuvesatriani Posts: 561
    edited October 2021
    Try change pin option in Windows>Panes(Tab)>Tool Setting from Origin to end Or Both .
    Last time I`ve tried , its work perfectly with G1 and G2 figures but keep sliding when used for G3 and G8 figures .
    525 x 945 - 138K
    Post edited by juvesatriani on
  • ImagoImago Posts: 5,798
    Yes, that's really useful, I used it a bit in some projects. It's not perfect (it tends to make the walks a bit rigid) but very good to make a good base.
    That's certainly something I don't understand. There are people who at the beginning of a sentence praise DS for its animation functionality, but at the end of the same sentence and after a comma, lament its poor results.
  • There is an add-on called LimbStick by 3D Universe that may do what your after. I haven't used it as of yet, but as the name implies, it sticks a hand or foot to a target. I suppose one could place target obgects, (e.g. small planes) Then by moving the planes, create a walk or whatever movement. May be worth looking into.
    https://www.daz3d.com/limbstick-for-genesis-3-and-above
