C66 Billboard Builder - Solved
I just purchased this, but when i attempt to start the script it says that the cg66 graphics plugin is not installed. I've tried to install the plug in with both the exe file and downloading through DIM. I even tried to manually copy the dll from inside the DIM file into the DAZ plugins directory. When i try to start the script it still says the plug in is not installed and quits.
Not sure if it would matter, but I do use a content library on a different drive and have changed the install path in DIM
Any help would be appreciated, thank you.
Post edited by tsb2535 on
Maybe try asking in the commercial thread for this product? https://www.daz3d.com/forums/discussion/525916/released-billboard-builder-commercial#latest
