bug report worthy or is it just me? Full Screen toggle
StratDragon
I'm on 4.15.0.28, because .30 is too instable on my computer for whatever reason, and my machine is a flying gascan (specs in sig). I noticed in some instances if I toggle the full screen either way the program may freeze up DS where force quit or reboot is the only way out. The crash happens more times in Iray preview but I've seen it happen in wireframe and textured mode which I work in throughout scene making. It is inconsistent. I'm running 3 displays, two of which are driven entirely by the CPU (intel 630) and those drivers are up-to-date. my viewport display is running at 1080, vertical portrait which is being controlled by the windows display control panel, not the nvidia one. I'm running windows AV, thats it. this computer goes to maybe 3 different sites when it is connected to wi-fi and it's rarely connected.
As I write this I realize I may try to see if the Nvidia studio drivers should be doing the rotation, not the Windows panel. I'm using the Nvidia Studio drivers, not the game ones, I checked the version last night and it's still most recent.
I do not have multiple displays, I do not use the full screen option, I am running a lower end system than yours and with older drivers, game version, and the full screen just now did not give me any issues. Also going to note that I am using W10 Pro v2004 with up to date security patches. My monitor, HP Elite Display E271i, can go vertical but I dont bother as I have no need of it to do so.
So from what I read, I would guess that only one of your monitors goes full screen when you do "Shift+ F11" and the other two do not. I am curious if that is confusing Windows. Did you do this without issue in the past prior to the build of DS that you are using?
the other two do not fill the screen when I toggle F11
also when texture lists spread across multiple displays and extend past what can be shown there is no way to scroll past the bottom of the list.
Can you connect your monitors to the 1660Ti?
I would disable the Intel GPU all together and use the Nvidia control panel to control all three monitors.
