Is the master54191 a legit Daz CMS file?
tonytriolatonytriola Posts: 20
As the title says, in my windows/temp directory is a file that can't be deleted because it's being used by Daz Content management System.
The file is 100kb.
The reason I'm clearing my temp directory is I suspect malware (or microsoft themselves) are attempting to install edge browser or some exploit behind my back (I get a notification from private-firewall that microsftedgeupdate.exe is trying to run - even though I blocked it previously).
Of course the filename may just be a ruse to install an exploit, I deleted all occurances and prefetch files from my drive.
So I thought I'd ask before going into safe mode and deleting the file.
Thanks for any info.
Post edited by tonytriola on
  • Is PostgreSQL running in the process list?
  • tonytriolatonytriola Posts: 20
    edited October 2021
    No, PostgreSQL doesn't show up in running processes...but ContentManagerServer.exe is running.
    I suppose I could just shut down the CMS, delete the file and reboot, but does the CMS need that file to run?
  • I shut down the CMS so I could get a look at the file with a hex editor. There's nothing in it (zeroed out) except for what may be a header and the only values other than 0 are in the first three 32 bit WORDS. But without any header-format info, it's meaningless.
    00 00 01 00 00 80 00 00
    01 00 00 00 02 00 00 00
    02 00 00 00 00 00 00 00
    So it's a 102.4k file with all zero values except for the first 24 byte block.
    I'll just leave it alone for use by the CMS.
    Thanks for taking a look.
  • Richard HaseltineRichard Haseltine Posts: 110,814
    edited October 2021
    I think that is the old Valentina system - you can safely uninstall the whole thing if you are using Daz Studio 4.9.x.x or later. Valentina, unlike psotgreSQL, ran as a service so it was always on - the on/off switch in DS is for PostgreSQL only.
