Figures rendering as blank space
holden_attradiesholden_attradies Posts: 121
I've had this problem happen to me a couple of times now. I'm pulling renders, changing poses and at one point one of my figures starts to not render. The rest of the shot renders fine but one of the figures will simple render as blank space showing up white, although usually her hair and clothes will turn out fine.
If I go back to my last save this seems to fix it. I don't know whats causing this, any suggestions?
  • JonstarkJonstark Posts: 2,738
    Sounds like maybe a texture change was inadvertently made on the character, maybe in the course of a keyframe animation or something. What software you using?
  • fixmypcmikefixmypcmike Posts: 19,742
    It sounds like a shader has gotten corrupted -- if you go to the temp folder (default in Windows is C:/Users/[username]/AppData/Roaming/DAZ 3D/Studio4/temp), go into the shaders subfolder there and delete the contents of the brickyard subfolder, then DS will regenerate the shader files.
  • MJWMJW Posts: 540
    This frequently happens with me. I have usually simply saved the scene, closed DS and reopened, then reloaded and Bob's your parental male sibling.
