Basic Question about Export and Import
sasa Posts: 45
edited February 2015 in Bryce Discussion
How can I save , on one computer , a model textured within Bryce 7.1 Pro ? and then move it to another computer to populate a existing Bryce 7.1 Pro landscape ? Please
Good Job !
http://www.bryce-tutorials.info/bryce-tutorials.html
Post edited by sa on
    Save it in your preset library then transfer using a usb thingy, a memeory stick or whatever you call it, and import it into your other preset library
  • sasa Posts: 45
    Thank You chohole ,
    that does seem like the logical thing to do ! What about the Materials ? For some reason this reminds me of the fear of using the transporter for the first time !! Something is going to get lost during the conversion process .
  • HoroHoro Posts: 11,740
    @starmijo2012 - if you save the object into an Object Library, the materials are retained. You can save it in an existing library (e.g. User) or create new folders and new libraries. Then you can transfer the whole library to the other computer. I recommend that you back up all your libraries (the Preset folder) from time to time. Chohole's tip is spot on.
    Exporting the object via File > Export creates image materials that are much less good then the original.
  • sasa Posts: 45
    edited March 2015
    chohole - I agree with Horo , your tip is spot on !
    Horo - ' if you save the object into an Object Library, the materials are retained. ' that pretty much sums it up for me ,
    And thank you for your recommendation ' that you back up all your libraries (the Preset folder) from time to time. '
    Thank You for your help :)
