Noob Question - Headshop 14 doesn't work?
Hey all!
As the title suggests, I'm new to Daz.
Let me know if this should go somewhere else since it's mostly about Headshop.
  • I bought a full $109 license to Headshop 14 (mistake?), because I liked the advertised features, however it doesn't seem to work as advertised.
  • I have a default installation of DAZ 3D using the Daz Install Manager (installation directory is C:\Program Files\DAZ 3D) with nothing else added.
  • I have closely followed the tutorial videos and text multiple times.
  • I am able to launch DAZ (current standard version 4.15 Pro downloaded straight from website), and I am able to click Edit>Start Headshop
  • However when I actually attempt to export anything I get the following error from attempting a folder that does not exist on the current installation (Runtime/Faceshop). There is no Faceshop subfolder there:
************** Exception Text **************
System.IO.DirectoryNotFoundException: Could not find a part of the path 'C:\Users\Public\Documents\My DAZ 3D Library\Runtime\FaceShop\fs\SmoothedModelTextures\G8FBaseFaceMapD_1001_smoothed_color_retouch.jpg'.
   at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
   at System.IO.File.InternalCopy(String sourceFileName, String destFileName, Boolean overwrite, Boolean checkHost)
   at System.IO.File.Copy(String sourceFileName, String destFileName, Boolean overwrite)
   at RH.Core.Render.ctrlRenderControl.SaveTextureToPublicDocuments(String specialExportPath) in D:\projects\headshop\source\headshop\RH.Core\Render\ctrlRenderControl.cs:line 4176
   at RH.Core.Render.ctrlRenderControl.SaveHead(String path, String specialExportPath, Boolean saveBrushesToTexture) in D:\projects\headshop\source\headshop\RH.Core\Render\ctrlRenderControl.cs:line 4189
   at RH.Core.frmMain.Export() in D:\projects\headshop\source\headshop\RH.Core\frmMain.cs:line 2221
   at RH.Core.frmMain.OnExport_Click(Object sender, EventArgs e) in D:\projects\headshop\source\headshop\RH.Core\frmMain.cs:line 733
   at RH.Core.frmMain.exportToolStripMenuItem_Click(Object sender, EventArgs e) in D:\projects\headshop\source\headshop\RH.Core\frmMain.cs:line 738
   at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
   at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
   at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
   at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
   at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ToolStrip.WndProc(Message& m)
   at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4420.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Rh.HeadShop
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/DAZ%203D/HeadShop%20plugin/Rh.HeadShop.exe
    Win32 Version: 4.8.4400.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    Win32 Version: 4.8.4360.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    Win32 Version: 4.8.4390.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
RH.Core
    CodeBase: file:///C:/Program%20Files/DAZ%203D/HeadShop%20plugin/RH.Core.DLL
System.Configuration
    Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
    Win32 Version: 4.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
FaceSDK.NET
    Assembly Version: 6.2.0.0
    Win32 Version: 6, 2, 0, 0
    CodeBase: file:///C:/Program%20Files/DAZ%203D/HeadShop%20plugin/FaceSDK.NET.DLL
msvcm90
    Assembly Version: 9.0.30729.9625
    Win32 Version: 9.00.30729.9625
    CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9625_none_508ef7e4bcbbe589/msvcm90.dll
OpenTK
    Assembly Version: 1.1.0.0
    Win32 Version: 1.1.1536.5788
    CodeBase: file:///C:/Program%20Files/DAZ%203D/HeadShop%20plugin/OpenTK.DLL
RH.MeshUtils
    CodeBase: file:///C:/Program%20Files/DAZ%203D/HeadShop%20plugin/RH.MeshUtils.DLL
RH.AssimpNet
    Assembly Version: 3.2.0.0
    Win32 Version: 3.2
    CodeBase: file:///C:/Program%20Files/DAZ%203D/HeadShop%20plugin/RH.AssimpNet.DLL
OpenTK.GLControl
    CodeBase: file:///C:/Program%20Files/DAZ%203D/HeadShop%20plugin/OpenTK.GLControl.DLL
PresentationCore
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
WindowsBase
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
Emgu.CV.World
    Assembly Version: 3.3.0.2824
    Win32 Version: 3.3.0.2824
    CodeBase: file:///C:/Program%20Files/DAZ%203D/HeadShop%20plugin/Emgu.CV.World.DLL
Accessibility
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
RH.ImageListView
    CodeBase: file:///C:/Program%20Files/DAZ%203D/HeadShop%20plugin/RH.ImageListView.DLL
  • barbultbarbult Posts: 27,603
    I can't help with the Headshop technical problems. I hope you find the help you need, but know that you have 30 days from date of purchase to return the product for a refund, if you are dissatisfied with it. If you decide to go that route, submit a help request to ask for a refund. $109 is way too much to waste on something that doesn't work.
    edited October 2021
    throwawaytales said:
    .... edited ...
    Yes, and so the solution is to put one there ;-)  EXACT location. Might want to then make a desktop shortcut for it. And after each texture set is made, go there and either slide it into another sub-folder you make there OR transfer them to another folder [i.e. to an external drive] BECAUSE each project will over the previous one if/when using the same figure's textures.
    Also make sure that the D/S temp folder is the Default one as per image.
    620 x 580 - 30K
    Post edited by Catherine3678ab on
  • Throwawaytales has had a skype/screen share session and we were able to find a solution in 5 minutes flat. He also forgot to mention, that he installed HeadShop via DAZ Central and IM - neither of which can be used with HeadShop. As the README clearly states, HeadShop has its own installer that, when used, installs on the correct location.
  • Well that's a major minor detail! Glad to hear that he got it working :-)
  • smb675smb675 Posts: 12
    I just correctly installed headshop14 2022 and when I go to find it in daz its not where the pdf or video tutorial say is. It is installed in the daz folder I just cannot find it IN daz any ideas?
    Scott
    Good afternoon!
    How did you solve this problem?
    I have the same situation. I would be very grateful for your help
    Good afternoon!
    It is always install issue. To solve install please visit the following tut:
    Follow steos carefully, don't skip! If still no luck, we can have a skype screen share - works 100% of the time.
    Let me know: [email protected]
