Any Way to Disable the Auto Shaping in Studio?
souji_monaru
I was just wondering if there's any way you can stop Studio 4.6 or higher from re-shaping the figure when you bend it etc. Sometimes I just
want the look I see when first bending or moving the character around, but when I let go the program alters the figure to an unrealistic look
(at least in my opinion). Just wanted to know if this can be remedied or do I need to get some sort of morph to fix it?
What I think you are seeing, is the figure changing from High Resolution to Base resolution in the viewport when posing the figure, and then back to High Res when the posing is finished.
If you got to the Tools settings pane, Window > Panes (Tabs) > Tool Settings, and set the During Manipulation > SubDivision to Persistent (Off) then it wont do that. It may slow down your viewport when using larger scenes though.
