Twist Braids Hair misaligned
doorknob22doorknob22 Posts: 64
Hi!
I'm trying to fit Twist Braids Hair on G8.1F (Sabah). In the preview it seems all right but when I render there seems to be some ugly misalignment at the forehead. Note: I used a scale morph to make the charcter slightly shorter (91% scale). When I return the charcter to 100% it renders normally.
Any idea what might cause this?
1920 x 1080 - 473K
Post edited by doorknob22 on
  • If it's OK in preview but not in render it is often displacement that is the issue.
    So... how do I fix displacement?
  • You'd need to check the surface settibgs on hair and figure, see if either had any displacement, and if they did whether zeroing it resolved the problem
