I want to fit clothing which is .obj on DAZ3D. Is it possible.
Hello. I would like to dress Genesis8 or Victoria4 in the clothes from the obj file, but I'm not sure if it's possible.  I used Daz studio. As far as I could do, the clothes that is obj file didn't follow the pose.
  • LeanaLeana Posts: 13,618
    edited October 2021
    An obj is just a static object, it won't follow poses.
    You can try the following things:
    • Apply a dForce modifier to the clothes and run a simulation. It may or may not work well, depending on how the clothes were built.
    • Rigging the clothes as a conforming item. For Genesis 8 you would use the transfer utility for that, for V4 you would use the legacy figure setup tools as she uses a different type of rigging.
    Edit: both of those assume that the obj clothes would actually fit the figure you want to use them on. If not, you'll need to adjust them first, probably with a modelling app.
    Post edited by Leana on
