Keiko 6 no UV map for female Anatomical Elements ?
ReilanT 3D pictureReilanT 3D picture Posts: 11
edited December 2015 in The Commons
hello here, i'm an happy owner of the cute Keiko 6, but when i look all pack ( Starter, Pro and Manga ) i dont see female Genitalia same like my Aiko 6 pro Bundle, it's normal ?
thanks !!
Post edited by Chohole on
  • cwichuracwichura Posts: 1,042
    The filelist does not show a UV for the genitalia: http://docs.daz3d.com/doku.php/public/read_me/index/20631/file_list
    As to if that is intended or an oversight, I have no idea. Knowing DAZ, I wouldn't be surprised if it was intended. But to really find out, you might try submitting a ticket.
  • Design Anvil - Razor42Design Anvil - Razor42 Posts: 1,250
    I have a feeling this may be connected with these figure being seen as teen or child like characters so, no support is offered in this ... er ... area.
  • ReilanT 3D pictureReilanT 3D picture Posts: 11
    maybe yes... but aiko 6 have UV map for that .. well, maybe i go to see at Render O tica ^^ or use Keiko shape with Aiko Skin
    Aiko 6 was never intended to be a teen which is why she has rather more ample 'assets'. She also comes with rather more showy clothing in her bundle compared to Keiko.
    it's true it's true, when i mix aiko and Keiko for make an manga Character with Defaut map skin texture, i can make a cool ecchi/hentai Character :)
  • BarubaryBarubary Posts: 1,233
    edited February 2015
    If memory serves me right, 3feetwolf, the creator of "3feetwolf’s New Genitalia For Victoria 6" over at Rotica has done an outstanding job, so far, keeping his genitalia geograft up to date with DAZ's releases.
    Post edited by Barubary on
  • Yes but those genitals are a little funny looking in my opinion. Is there a workaround for this? I tried applying the keiko material to the genitals, however it doesn't fully cover them, there is a big area on the thighs that remains white.
  • nicsttnicstt Posts: 11,715
    I saw an ad for a version two of the gens; btw, check the UVs for the geocraft, that can affect how textures are laid out.
  • Version 2 of 3feetwolf's gens do support all of the DAZ character bases, and even supports V4 and V5 texture sets.
    Afraid I have no clue how to do this...
  • Select the geograft, go to the surfaces panel, and locate the "UV Set" dropdown.  This is a list of all the UV sets the geograft supports.  It should be set to the same UV as the rest of the character - i.e. for Keiko 6, the UV dropdown should be set to Keiko 6.
    Ok I found it, however Keiko 6 is not one of the options there. I tried all the characters presented (only about 5 out of the 15 or so characters I have installed??) but none of them cover the white area. I do have version 2 of 3feet wolf gens also, but these also do not provide support for keiko 6.
    It's hard to believe it's this difficult! It seems like there should be a way I can just "copy" the skin color of the rest of her body, and apply it to the genital area, it's exactly asking a lot it seems....
  • RCDescheneRCDeschene Posts: 2,817
    Yeah, teens and significantly stylized characters don't get genitalia mats, I've noticed.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,507
    you can try map transfer on the hip texture then apply that
    ie from Keiko to Aiko then use Aiko's UV on geograft
  • Could you explain what you mean, I'm a little confused. Why would I do anything with Aiko?
    I want to apply the genesis 2 genitalia to Keiko 6, then give them skin color the same as the rest of her body.
    If I simply apply Keiko material, it does it correctly for 85% of the area, but leaves 15% white area unapplied.
    There is no alternative UV mapping for the genitals to match Keiko's alternative UV mapping.  You need to use 'toon' textures for a character base that has matching UV mapping for body and genitals, and that would be Aiko 6 (possibly The Girl 6 too).
    DAZ tends to err on the side of caution when it comes to the base figures and including genitalia in the pro bundle.  If there is the slightest chance a figure can be seen as a minor or underage in some way, they don't include the genitalia or the UV map for it if the figure has a unique UV.  It avoids problems with the credit card processor and PayPal.
