Hair for Victoria 3.0
Hi everyone!
I need your help for Victoria 3.0 and her hair.
I bought her about a week ago. I can put on her dresses and accessories but hair don't fit on her. So I were wondering: Did I do something wrong or am I suppose to buy her hair to make it works? Free hair doesn't work even if I put "Fit *name of the hair* To..."
Hope you will help me soon!
Bye
What hair are you trying to fit to V3, can you give a link?
Hair can come in two types, Figures and Props. Figure hair made for Poser (CR2) is usually made to 'Fit To' a particular character like V4 or M4 or Aiko etc.
If the hair is not made for V3, then don't use the Fit To option. Load the hair, and place it to where you want it to stay. You may need to use the Scale tools as well if it is too small or too large.
Once you have it in place where you want it, Parent it to V3 by dragging and dropping the Hair item onto the Head of V3 in the Scene pane.
There is a chapter on Parenting in the User Guide, Page 24 which you can get from the Help menu in DAZ Studio.
Thank's a lot!
You need to select the Hair in the Scene pane, and use the Translate tool (Alt+Shift+T) and move the hair to where you want it.
Your image is very small and difficult to see, you can post a much larger image directly to the forum using the Browse button just above the Submit Post button.
Now another question (tell me if it makes you angry haha): It all worked as well, but now when I want her to move, the hair and the hat don't move with her. What am I suppose to do?
You must 'Parent' the hair to the figure, so that it moves along with it, that is what parenting means ;)
Once you have the hair where you want it, select the hair in the Scene pane, right click, and select 'Change Parent' Select the body part you want to parent the hair to (Head?) then that should be it.
HALLELUJAH!
Thank you so so so much!
My pleasure!
Glad you got it to work.
