change parameter to 0
so i noticed my characters loaded looking like crack adicts, and after browsing all morphs i noticed a few had their value loaded to 100%. i tried going to parameter setting and set the "default" to 0, but it just resets to 100 when i quit that window. how can i permanently keep it at 0?
  • Set the morph dial to 0.
    File>Save As>Support Asset>Save modified Assets.
    This will change the DSF files to the new default.
    You can also create a new preset, character preset or morph preset, to load the morphs at 0.
    Be sure to check for controllers and sub-dials(Gear icon) to make sure that something else isn't causing the non-zero load.
    MIght have to modify multiple files.
    Also, be aware of any updates to the file that may undo this change, or correct the error.
  • KRISHANKOKRISHANKO Posts: 99
    edited October 2021
    hey that worked, thanks! now to see if theres any ninja morphs on females. i had to delete a few models entirely because of this problem before.
    wait, no. unexplainably, the morph went back to 100 when i loaded a third character. (with the save modified asset)
    edit. fixed it. thanks again!
    Post edited by KRISHANKO on
