Poser, OBJ and Genesis 2 morph problem
asr1010asr1010 Posts: 0
I created a shirt in Zbrush and exported it as OBJ, i imported the OBJ back to Poser, go to > Setup, add bones from Genesis 2, select the chest/breast morphs and then i conform this new figure to the Genesis 2 model. This method is working with Victoria 4 but with Genesis 2 seems to have no effect so the Morphs (Chest/Breast size etc) are not working.
I tried to, once conformed it, use DSON Importer > Transfer Active Morph, with no luck.
By the way, the Up/Down, Side/Side morphs of the basic female are working. Sure i am missing something but what? Anybody has a clue?
    Poser can't create a TriAx weight mapped figure nor can it create a DSON file. You need to weight map and rig your shirt in DAZ Studio.
  • frank0314frank0314 Posts: 15,116
    If your looking to use it in Poser then you need to rig in Poser. Same goes for DAZ Studio.
    Clothing for use with Genesis can only be rigged in DAZ Studio, regardless of whether it is used in Poser or DAZ Studio. Clothing for V4 can be rigged in either pogram.
