How to find an Item you already put in your scene
Sometimes i'll add a simple prop or whatever to my scene and later on find out I need to change its colour or something along these lines and will forget where exactly I found the thing in the content library on the left. All I will know is it was for G8f for instance and was a clothing item so i'll go to these lists and have to sometimes spend aaages scrolling down looking in folders to get it. Is there a simpler way of being able to directly locate the item you used before in your scene from the content library without also having to leave the Daz screen? Thx all.
  • IceCrMnIceCrMn Posts: 2,334
    edited October 2021
    That sounds like a good feature request.
    Being able to right click an item in the Scene pane and have the option to "Show in mapped folder" would be a very welcome change.
    Post edited by IceCrMn on
  • FauvistFauvist Posts: 2,291
    I make a screen capture of everything.  So when I find something in the conent tab that I add to my scene, while the icon for the item is still highlighted, I make a screen capture showing where it's located in the list of content.
  • margravemargrave Posts: 1,822
    Daz Studio's asset browsers badly need an overhaul, to add favorites, bookmarks, viewing history, etc.
    However, if you go to the scene tree, click the icon in the corner, and go to Edit -> Scene Identification, it will show you the file path to the asset.
  • ShelLuserShelLuser Posts: 749
    This is basically why the smart contents pane exists; it allows Daz Studio to look up associated items for the currently selected item. So if you want easier access then my suggestion would be to add the item and it's material presets to the Daz database ("smart contents pane") by adding the required metadata (basically the file type and the category it should be in).
    Once that's set up Daz will do exactly as suggested.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,712
    I usually look under surfaces to see where the textures live by browsing to one.
    Not always helpful as PAs often use weirdly named vanity folders (initials abbreviations) for textures but offers some clues, if you can decipher the PA name at least you can browse their store page and unhide items you own.
  • DrekkanDrekkan Posts: 460
    K so i guess there isnt anything that allows you to do it. Weird as I would had thought it was something simple that would had been in daz from the getgo its really an inconvenience having to look things up again and again. A product to pinpoint things in the content library is a good idea!
    I told you exactly how to do it: go into Scene Identification and look at the path to the asset.
